My full suspension purchased list. Missing anything?
industrialfish
So does it look like I'm missing anything?
(Rear)
ACDELCO 506-623 Rear Strut x2
DORMAN 905501 Rear Trailing Arm x2
GMPP 12498642 SWAY BAR REAR 19MM
MOOG K6662 Rear Stabilizer Bar Link x2
MONROE 902969 Rear Left Strut Mount
MONROE 902968 Rear Right Strut Mount
MONROE 63973 Rear Strut Bellow x2
MOOG K5350 Rear Coil Spring Insulator x2
(Front)
ACDelco 506-273 Front Strut x2
MEVOTECH MES3459 Tie Rod End x2
DORMAN 520165 Left Lower Control Arm
DORMAN 520166 Right Lower Control Arm
DORMAN 927100 Front Stabilizer Bar Assembly
MONROE 902973 Front Strut Mount x2
MONROE 63622 Front Strut Bellow x2
MOOG K5349 Front Lower Coil Spring Insulator x2
MOOG K80923 Front Upper Coil Spring Insulator x2
(Misc/Both)
DNA Motoring Springs x4
ZZ-APW-BLACK Anti Pogo Washers x4
WESTAR EM2796S Solid Motor Mount
WESTAR EM2712S Solid Transmission Mount
Vinnies Spacers
Lateral arms aren't really something that most people replace, the trailing arms are what should be done.
Also you could save yourself like 100 bucks by taking apart your old struts and re-using the dust boots and rubber insulators. I did that because I want to save cash.
If you are looking for lateral links/track bars, I'm selling all 4.
Dorman Track Bars/Lateral Links (2) 905-503 (2) 905-502.
$100 for all 4. Will not break up set.
Have a little over 5k on them.
Yeah survey says lateral arms don't tend to need replacing unless damaged, same with inner tie rods, so I passed on those. I did get rear trailing arms though.
I coulda saved some money reusing the rubber bits, but I don't want to end up needing them and then having to order them, or get raped at autozone. Better safe then sorry. If they are in good condition, that just means someone here will get a good deal on them :P
God dammit. I just crawled under the car, and rear passenger side trailing arm is ficking mangled (I blew out that tire on a pothole a month ago), and so it looks like the rear passenger lateral arm has a little bowing to it.
EDIT: Nevermind. Took a straightedge out there to be sure. Looks can be deceiving, they are fine. But damn that trailing bar is bent at like 15 degrees in two directions.
