chatbreaker
Aright, I just got done installing two new wheel hubs and both outer tie rod ends. Took about 2 hours start to finish, plus extra time to chop out a stripped bolt on the driver's side hub. Car's quiet, and the steering is much more responsive now (old tie rod ends were far beyond shot) and now I have a new issue
Took the car on the highway and the steering kind of pulls me all over the lane. It feels like tie rod ends are loose, but I checked for play in the steering and there is none. I noticed that when I removed the driver's side tie rod, it required 15 turns to remove, and the passenger required only 14, but that might have been due to a previous alignment, I'm not sure.
I'm going to be taking the car in for an alignment check some time this week, and have them "give me a quote for anything they find wrong" which really means they're just going to be giving me a shopping list ^_^. Of course, once all the parts are replaced, I'll be getting an alignment done.
Also, it's probably worth noting, the inside of the passenger tire is worn down almost to the belts. I know that the passenger side sway bar end was snapped off, so I replaced the sway bar with new bushings and end links last week.
Is it possible that this "wandering" is suspension related, or is it more likely steering related? Could the inner tie rod ends be worn out as well?
Thanks.
Also: Moderator, I didn't see a steering section in the forums, but if there is one, please move this thread to the appropriate location. Thanks.
Thanks.
