    TIPS:
Spring Cleanout - Lots of Stock and Aftermarket Performance Parts
Zef_66
I have a bunch of stuff that I want to get rid of. Just a whole lot of parts from my years driving and modding 3800s. Most of the stuff, if I don’t sell it I will be scrapping it. I will be listing all parts without shipping included, unless otherwise noted. In most cases, it is not really worth my time to package and ship. So they will be pickup only.
If you are interested, make me an offer on everything and come pick it all up. I will let it all go for a steal.
L67 Block & Crank - $50 picked up
L67 block & crank with 160k miles on it removed from my 1997 GTP. I had two chipped pistons and replaced the engine with an L32. The block and crank are still good. The pistons were removed and I no longer have them or the rods. Just what is pictured.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1499_zps18791b2f.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1500_zps173741e5.jpg
L67 Short Block - $200 picked up
L67 short block removed from a local 2001 GTP with 150k miles on it. This was running fine when pulled. The transmission had a bad TCC solenoid and the owner replaced both the engine and tranny. The mating tranny is also for sale below.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1528_zps30b80268.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1531_zpsa25d82c7.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1532_zpsf39b9ed6.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1530_zpsfd70830c.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1529_zps167e237e.jpg
Stock 2001 Regal GS Full Exhaust - $50 Picked up
This is a complete exhaust from downpipe to chrome exhaust tips. Completely stock and included O2 sensor. This has roughly 160k miles on it and was removed from my car to put headers and 3" on. There is very little rust on this system and it seems quite solid. The only thing that may cause an issue down the road is the resonator. There is some rust at the seam and I tried to take a picture to show that. The cat is worth the $50 alone in scrap.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1483_zps0c4e3eeb.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1485_zpsadd927db.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1486_zps5e18fb38.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1487_zps52c09fa6.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1488_zpsd4015a41.jpg
TRW Hypereutectic Pistons - $60 shipped
I bought these awhile back when I was going to rebuild for a turbo. They were used in a GN and are supposed to be low miles. Everything looks good on these. The casting numbers read H521AP H644P. According to Flatlander Racing, these pistons are for Turbo/SC applications, 3.8" bore, 7.57 Comp ratio on 48cc heads. They list at $240 for the set.
http://img.photobucket.com/albums/v323/Zef_66/CL/P1010396.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/P1010395.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/P1010405-1.jpg
4T65E-HD Transmission - $100 ea Picked up
I have 3 of these that all will need rebuilt, but all are good cores. And all have the HD differential and shaft that is needed for upgrading a non-HD 4T65E. These upgrades usually sell for $100-$125 alone. Please read below each picture for a description of each individual transmission.
http://img.photobucket.com/albums/v323/Zef_66/CL/IMAG0329_zpspdpgs3cs.jpg
4T65E-HD transmission removed from a 2001 GTP with 93k miles on it. There was some pieces in that transmission pan that appeared to be from a bad sun gear. Everything else was solid. Stock torque converter included.
http://img.photobucket.com/albums/v323/Zef_66/CL/IMAG0332_zpsmoxfyl4f.jpg
4T65E-HD removed from a 2001 GTP with approx 150k miles. The TCC was supposedly acting up. Again, could be an easy fix or core for a good rebuild. Stock torque converter is included. Mating engine is listed above.
http://img.photobucket.com/albums/v323/Zef_66/CL/IMAG0330_zpsmishbylf.jpg
4T65E-HD removed from my 2001 Regal GS with 206k miles on it. The TCC went bad and the torque converter would not lock up. Everything else was fine with the transmission. I personally changed the fluid and filter many times in this and it shifted well. Could be an easy fix if you wanted to pull the side cover, replace the solenoid and drive it. Or it would make a great core for a rebuild. Stock torque converter is included.
L36 Heads - $10 per pair Picked up
I have 2 sets of these. And one set of valve covers that I will include if you need/want them. Mileage unknown.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1502_zpsd3488437.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1533_zps09039927.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1505_zpsefe541df.jpg
Stock Buick Regal Chrome Wheels - $10 ea Picked up
I only have 2. These are decent used wheels for a daily driver. No real curb rash, but they are nowhere near perfect. The chrome is peeling from the inside and the tires are shot. If they don't sell, they are getting scrapped.
http://img.photobucket.com/albums/v323/Zef_66/CL/IMAG0337_zpsuuzdoskw.jpg
PLX M-250 Wideband O2 Sensor - $SOLD
Buick STB - $10 ea Picked Up
I have 3 STBs (only 2 pictured) that are stock on a Buick Regal. These are a nice mod to stiffen up the body flex on W-Bodys.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN0751Medium.jpg
Buick STB Mounts - $15 ea shipped
These are the stock mounts to mount the front STB bar. I’m not sure if you can do it on the rear or not. I have two sets. One new and one used. May give a discount on the used set if you buy something else. Always willing to discuss offers.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN0750Medium.jpg
L67 Engine Covers - $5 ea Picked up
I have 2 of these. Nothing special. Just a stock engine cover for the L67.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1501_zps9d8d554d.jpg
L67 Oil Pan - $10 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1504_zps4870f2ee.jpg
L67 Intake - $10 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1503_zpsb21cab1d.jpg
1997 L67 Alternator Bracket - $10 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1506_zpse8dd96a7.jpg
1997 L76 Alternator & Bracket - $30 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1513_zpse502cc99.jpg
L67 Alternator - $20 ea Picked up
I have 2 of these.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1516_zps63dd5411.jpg
L67 Flexplate - $5 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1535_zpsdfa9aa42.jpg
Stock Trailing Arms - $5 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1510_zpse328c246.jpg
Stock Regal Rear Sway Bar - $10 Picked Up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1514_zpsc0974248.jpg
Stock L76 Throttle Body w/ Sensors (IAC, MAF, TPS) - $50 ea Picked up
I have 2 of these.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1508_zps52c7c81c.jpg
L67 Eaton M90 Supercharger - $100 Picked up
Unknown Mileage. Nice coating still on the rotors. Overall a good used unit.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1521_zps5ed029a5.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1522_zpsbed5efaa.jpg
Stock L67 Lifters & Pushrods - $10 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1525_zpsae0ffc21.jpg
Stock L67 EGR Valve & Pipes - $20 Picked Up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1526_zpsc7075f42.jpg
Stock L67 PCM - $20 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1520_zpsbc6f36a7.jpg
Service No. 09380717
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1507_zps96c74f4a.jpg
Struts and Springs - $50 Picked up
Stock suspension including front and rear spring, struts, top mounting plates, etc. This was removed from my 2001 Regal GS with 150k miles on them.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1511_zps81a3abeb.jpg
Stock GTP Trailing Arms - $5 Picked up
Miscellaneous Suspension Parts - $5 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1515_zps38d6aede.jpg
L67 Exhaust Manifolds w/ Shielding - $20 ea set Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1518_zps5ef8a548.jpg
L67 Rear Exhaust Manifold & Crossover - $10 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1519_zps91ee6a87.jpg
L67 Stock Fuel Injectors - $SOLD
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1524_zps0aa07f37.jpg
L67 Stock Balancer/Crank Pulley - $5 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1527_zpsf26c8032.jpg
L67 Stock Torque Converter Code JTFM - $5 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1517_zps7ca68f7e.jpg
Used AutoMeter Phantom Series Gauges - $35 ea or $60 for both Picked up
Sending unit for Oil pressure gauge included. All wiring and mounting for both included.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1549_zpsef021736.jpg
Buick Regal 97-02 3 Gauge Pillar Pod - $40 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1550_zps71c3d0b3.jpg
Pontiac Grand Prix 97-02 3 Gauge Pillar Pod - $30 Picked up
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1551_zpsaf44e0f6.jpg
Buick Regal Cupholder Console & Trim - $80 Picked up
Works fine. This is from a 98 GS. I bought from Morad and ended up fixing my old one as this is Light Grey and I have dark grey interior.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1552_zps0e61e640.jpg
HUMount Head Unit Mounting - $50 Picked Up
I used this in my 97 GTP and it looked great. There is a problem where the screws that hold the faceplate on have broken out the plastic in the corner. This caused the trim to rub through the black paint on the face. This is not noticeable when it is installed and really doesn’t cause an issue. But I thought I would mention it and adjusted the price accordingly. Head unit can be included for an extra $75. Here is a link to the product:
http://maptechenterprises.com/storefront/index.php?main_page=product_info&cPath=1_5_6&products_id=7
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1542_zpsd6b2a2ea.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1546_zps4ad90cf5.jpg
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1544_zps7b0a7339.jpg
HUMount Head Unit Mounting - $10 Picked up
This is for only what is pictured. This mounting plate uses the old style bulbs which several have burnt out. Since they are glued in, it is hard to replace them. So I was able to buy just the new style mounting plate. This was in my 97 GTP.
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1548_zps8a8ef985.jpg
4T65E Foreward Band - $50 Shipped
I bought this when rebuilding the tranny for my 01 Regal GS, but didn’t end up using it and missed the return window from Amazon. This is brand new and never installed. AC Delco PN 24213361. Here is a link to the exact product I bought:
http://amzn.to/1kXDiBs
http://img.photobucket.com/albums/v323/Zef_66/CL/DSCN1553_zps6fa4a20b.jpg
Grand Prix Black Hood - $Free Picked up
Black Hood from Pontiac Grand Prix. It's in rough shape. Clear coat is peeling. It has some sort of hood scoop screwed on. But it is straight and not dented.
http://img.photobucket.com/albums/v323/Zef_66/CL/IMAG0339_zps5nhvlll9.jpg
Back to the top.
I'm going to start scrapping stuff this week. If you want something, shoot me an offer.
