japslpr
This is the 4th axel I have had this happen to. The driver side axel destroying the boot causing grease to go everywhere!
I have replaced my driver side axel 4 times in less than 2 years. I get the axels from NAPA and generally get them warrantied out, but they are fed up with replacing my axel as well as I am.
The outer boot keeps rubbing a hole through the boot. But what is weird is that I have the GMPP Spring and Strut Kit, which GM designed, and only lowers the car .8" in the front and .6" in the rear, no cradle spacers to bring the engine down for my intercooler and I'm still splitting the boot. I know for a fact that the boot is not hitting anything except for itself.
Is there anything that can be done to correct this problem. I cannot shim the tranny mount and engine mount as it will raise the engine to much and my blower will hit the hood. But doing that mod and putting in cradle spacers I don't think would help either because I would just be lowering the cradle by 1/4" and inch which brings the tranny down and making the axel press in tight, but rasing it with the motor mount shims 1/4" would put me right back to where I am currently.
Any help would be much appreciated!
