Race Pellet Vs. Disconnecting IAT Sensor
But it also says you must run 100+ octane fuel.
Just out of the blue adding 4 degree's of timing is stupid, someone could go from 16-17 to 20-21 in the snap of the finger and that just about as fast a piston chips and goodbye motor.
Same deal but no check engine light with the resistor.
It wont bomb a basic setup but it will make race gas work. knock sensors USUALLY work ok and they work better when the timing is jacked up 4 across all flow.
