ffball33323
I got some retrofits from Classy..... New headlight housings, Morimoto Mini H1 6.0's, clear lense swap, Morimoto 3five ballasts, xb35 bulbs, 5000k.
Because I had some problems with the Motocontrol 9007 relay harness and had to keep removing my lights, I broke a tab on the bracket on the new passenger side headlight. Went to the junk yard and got another bracket. the bracket is a slightly different in one spot so I had to drill out a wider hole for the mounting screw for the clear corners.
Last night, my drivers side headlight started bouncing and is already driving me nuts. What have you done that's worked best? I was thinking of trying to wedge something under the inside of the drivers side headlight to try and angle it up a little bit right there because it kinda looks like the projectors need to be rotated a little.
After these pics, I aimed them up a little higher, but what do you guys think of these....
