    TIPS:
TDCRacing FWI
  • Thread starter Thread starter TDCRacing
  • Start date Start date
So does the Complete kit W/Filter not come with the Piece of metal that goes on the inner fender that has the hole in it?
The compleate kit comes with everything. The fenderwell block off plate is included in the Compleate kit.
Let me know if you need anything else.
The reason I was asking about this is because I received a complete kit for Christmas. You sent it to my father in Iowa. It was supposed to be painted black. It was not. No biggie. Also it does not have the block off plate in the kit? I want to get this put on but don't want to if it is not all here and I am gonna have to take it apart again later or something. :th_scratchhead:
Sorry, I was rushing to get it shipped out in time for Christmas for ya and compleatly forgot to paint it and put the blockoff plate in there.
I will send you the block off plate and send you some black paint to paint it with ASAP. Please send me a pm with you're name and address (if different than you're fathers)
Sorry for any inconvience and hope you had a good Christmas and have a good new year.
No big deal man! :th_thumb-up: Thanks so much for the quick response! I sent ya a PM with the requested info.
Have a good one!
OK so I am out trying to fit everything up for the install and I have a couple of issues
1. The adapter from the TB to the pipe is 2 big for the TB so I had to use one of the ones for the MAF to get it to fit correctly.
2. There is a bracket inside the fender that the pipe has to pass through. The hole is to small for the pipe to fit through. Do i have to modify the bracket or what?
3. There is no hole for the PCV to go in? What are my options for that?
I can send pictures of my issues if you have any questions about what is going on?
Also I am currently working on this and would like to have you call me if that is possible I will send you a PM with my number.
You may be better waiting untill i ship off that cover. Otherwise you'll have to re-install it all over again.
There is a bracket that needs to be cut off inside of the fender. Some do it with tin snips some do it with a sawzall.
Sorry i did not get you're message till now.
I also returned you're PM
Hey TDC,
I wanted to go ahead and install it now. Knowing I had to take it apart gave me a chance to test fit and learn for the final install. Learning how to do it with minimal damage to the fresh paint job it will have. I plan to fill all the scratches and sand the whole thing to a fine shine and then paint it. I cant see going through all that to get it all trashed while figuring it out. I might recommend some simple instructions be included. I will possibly provide a write up after my install is complete. Given I have time. I have been taking picture a lot along the way.
Any way at this point I am wondering what you recommend I do with what I believe is the PCV valve. It is attached with a hard hose and moving it seems to be an issue. Also I have noticed in past posts you included a grommet for other buyers. Will you be sending that with my other parts? Do you know the diameter the hole needs to be off the top of your head? What do I use in place of the hard hose if I need to move it? Last question is. You sent me 2 Reducing couplers and one straight through. I seem to need 3 reducing couplers. the straight through is 2 big for both my TB and MAF. I was able to rig it up for now but can not leave it this way it will not hold tight enough and slips off easy! So did I receive a wrong coupler or am I missing something?
How long will it be before you get my parts sent out? I really wanna get this done soon we are supposed to have fair weather here for a few days. :)
Sorry I have so many questions. I figured if I had questions them other buyers might as well. I figured I would just ask in the forum so others could use them for reference in the future.
By the way I did get it on tonight in a rough form and the "PCV" hanging out. It sounds AWESOME. But still icy roads around here so no idea how it FEELS!!
:D.......................:D............................:D................................:D.................................:D...................................:D
Thanks A Million!
Have a Happy New Year
Question...I did not receive my block off plate either, and it was not painted black. What all was i supposed to receive in my package? I ordered the full kit and I received the unpainted pipe and K&N filter only. This was for a 2000 Grand Prix GTP. I want to make sure I get all i need for the install, I'm fairly new to this. Thank you
Edit:I didn't receive any couplers or grommets or anything like that either
Pm sent.
I think i may have mixed some things up between the two of you. I'll get you the parts you need to install everything.
