2005 GP GT 123k Miles
Soooo I work off a dirt road that has horrible bumps and I mean HORRIBLE.. I have bottomed out several time's while going to work and I know my suspension shot! I hear clunking every time I hit a bump, my steering kinda wobble's now and my struts squeak when I hit a decent bump... I try my best to avoid them or go really slow but the road is just sooo bad... My plan is to replace most of the front and just let my gf drive the car until road isn't to bad and i'll drive the truck.
So far what I have "waiting till it's warm out" Moog Inner & Outer Tie Rod's, Stabilizer Bar link's, Bushing's but I was unsure about the what front struts to go with. I want to buy complete front's and I know you can't buy them pre-assembled which suck's.
From what I know that a whole front strut consists of...
Strut
Strut Below
Strut Mount
Coil Spring
Anything else I need let me know! Reason why I want all new is because these are not going in right away, I just want to pre-assembled until it's warmer out and do the whole front. I wanted to go KYB but on rockauto it does'n't show KYB coil springs or front strut mount which has me a little confused. Can you mix and match everything or no? I had in mind if you can mix & match... KYB Strut, MOOG Coil Spring's, Monroe Strut Mount, KYB Strut below, or if you guy's have any other better idea's on the best setup.
Last question, what else should I check/replace that I haven't said on this thread!
THANK"S =D
Strut
Strut Below
Strut Mount
Coil Spring
THANK"S =D
