What is this supposed to be?
So is that black the primer? It looked like a patch or something I wasnt sure. If I were you I wouldn't tape out the primer like that it leaves a hard edge and its harder to feather out.
Good plan! :th_thumbsup-wink:The reason I didn't feather anything on my car is because I'm only using the primar to protect the metal and the bondo. Once I have all the dents pulled out of my car I will be sanding all the primar back down to the metal and bondo, then I will sand the rest of the car and everything will be even, then the entire car will be primed!
its 15 or 16 years old. my factory one was long gone when i got my car, ( i drive a 98) and then the after market cat back rotted out on me and its all had to be replaced with new parts again.
And while your at it remove the door moldings and shave the holes.
Good work by the way
Sent from my HTC One using Tapatalk
