Old Thread
Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
a month maybe. it sits more then it moves too.
cheapest one ive found new is 60 off ebay.
not to bad, seen a lot over a 100 tho.
the jb weld deal, i used the tubes and did it in some cold ass weather. others have said the puddy works better.
to late, im getting a new one soon. enough of the band aids.
Back right tail light housing started fogging up. Also the turn signal is out, too. And possibly a brake light.
Low violent light keeps coming on but it doesn't get hot or anything and no leaks wtf
Taz238
Taz238
Last time I had that intermittent problem the entire system was sludged to the brim with Dexcool. Pop the radiator cap and if you see brown sludge, flush like hell and refill with green coolant.
Try to find red coolant if you can. Green holds static electricity. Put a volt meter in a glass of green coolant and it will register voltage..This will pop holes in your radiator over time.
hard start and chugging on cold start. fuel pump whines like a little girl. transmission acting funny, needs the side cover pulled and new PCS, chain set, 4th gear hub, and boost sleeve. Alignment. UIM gaskets. Coolant flush. New trans cooler. A/C condenser replacement. clean the interior.
that is all. nothing time and money can't fix.
mine fired right up, not a single sound of complaint, snow bound. i cleared the front windows, left all the snow on the hood for extra weight, and plowed through all that damn snow lol
Cooked trans, picking it up tommrow fully rebuilt flashed and external trans fluid cooler.
Time for LIM, once I get the time and courage to do it. Oil pan gasket is 'drippy'. Have a sloooooowwww brake fluid leak for the the last ten years, where its going is a mystery. Low coolant sensor don't work, disconnected. Oh and my drivers side floor mat has a five inch circle of cloth missing from the wear of my shoes over the years.
Car won't shift out of second gear when cold start but as soon as the engine/trans warms up it's like nothings wrong. What would cause something like that?
