trojanone1
Use lots of lube pb blaster wd40 whatever when flipping the dog bones
yup will do when I attempt it. Might let it soak overnight or something.
Mostly, I have a vvme kit. Their customer service is non existent when I needed to replace something under warranty.
You should try contacting them, 4 emails, handful of phone calls and voicemails with never getting a response. Plus they don't have updated warranty information on their site which led to me paying 10 bucks for a new ballast which is ironically the same cost of a new one :th_scratchhead:. OP I would go with TRS or Diode Dynamics over vvme. Diode Dynamics is a bit more expensive but they have a lifetime warranty. I dunno about DDM.I didn't like vvme website
Umm, I can't remember on my 02 I had to disconnect a something on the driver side. But I think you dont have too. Also there is something you can do to program the car so when you lock/unlock the headlights dont flash also. I saved it but lost it. I vote homemade intake, get the eye sore of a stock box gone.
EDIT: Found it how to disable lights flash when lock/unlocking.
To simplify blackarrows last post, this is what I did;
Here is a way to disable the the headlight flash on the 01-03 models altogether without cutting anything.
Step 1: Remove MALL PGM fuse from passenger fuse block in the glove box
Step 2: Place key in ignition, turn igntion to ON, not start
Step 3: Push LOCK button on key fob. You should hear one (1) chime
Step 4: If you do not hear one (1) chime when you press the lock button, repeat til you do
Step 5: Turn key to OFF position and remove key from ignition
Step 6: Re-install MALL PGM fuse
Step 7: You are done!
Takes all of 5 mins, if that. It just disables all light flashing, but you can still use your key fob.
Pretty sure that is the downpipe looks like the same design as my zzp
