Fuel pump rewire 04+?
Timing
I know there is probly something floating around somewhere on this but i couldnt find it. I got a rewire kit from zzp and im not sure what to tap into on my 04. Anyone done one and can point me in the right direction?
Was there no downloadable instructions?
I know plenty of people on GPONA griped about ZZP only including the 97-03 stuff.
Yea they give nothing about 04+ and when i googled it, every thread was about that but noone actually giving instructions.
I know its pretty obvious you have to just tap the fuel pump wire at the source but the way the 04+ is setup its hidden and you cant tell.
I will look when i get home and let you know if no one posts before then... i cant remember off the top of my head how i did mine.... i remember you tap into the gray or pink wire coming from the fuse box( i believe) then run it to your fuel pump where it just plugs right in... if my memory serves me correctly
thankyou
Fuq it I just went out to my car lol.. ya its the thick gray wire coming out of the fuse box... tap into that and run it to the pump panel then just plug it i to the pump connector
Sweet bro thanks alot, did you notice any improvement when you installed?
Ya i noticed a difference during hard acceleration.. the pump seemed to be more happy ya know
Well when Snowflake tuned my car he noticed my injectors were going static at wot so im hoping that the new injectors will help or the rewire, if not ill throw a new pump in there, i might do it anyway.
Ya it should help.. as well as new injectors...im on a stock pump and i have over 140k lol its still going strong
OK Ginseng here's where you need to tap into
Sorry for the chappy video the sun wasn't out while I was filming lol
Video:
Pics:
Yep no prob... i kept thinking it might be a white wire since you said it was at the pump.. but im pretty sure that one is grey lol its kinda hard to tell if it's just dirty or what haha.. but it's the only thick one on top like that
Its in and car fires so i guess i chose the correct one lol. Now ima go for a ride and see if this helps my car not be so lean
