Harmonic balancer
dezebe1
The other day i was doing some digging online for a harmonic balancer for our LeMons race car due to the fact that we are going from N/A to Supercharged. Looked at aftermarket SFI balancers and figured we need to keep the engine looking stock so in my search I found a different part number between a GTP L67 and a Bonneville L67. Had our parts dept. pull the factory GM part nubers for each and found the Bonneville balancer is 3lbs. heavier. GTP 8.5lbs vs. SSEI 11.5
So figured I'd pass it along if anyone is looking for a beefier stock factory balancer that will help control harmonics better.
Park Avenue and Bonneville have same motor mounts and pulleys, the balancer would be the same. Sure your comparing supercharged balancer from ssei with the gtp?
The Bonneville is a thicker outer metal ring...same diameter overall just thicker. I had both up at the parts counter and put both on our shipping scale at the dealership. Feels much beefier also.
Disclaimer.....I'm not saying this aving the complete rotating assembly is the correct one for a GTP but for our race car we perfer to use it due to the fact we will be having the complete rotating assembly balanced with new JE pistons, ARP rod bolts so just wanted to share if anyone else is looking for another alternative
if you don't belive it you can even look up the difference on rock auto. So yes I am 100% sure and I didn't mention anything about a Park Avenue. Look them up both as a 2003 model year
its mostly for NVH reasons the luxury cars got the heavier damper, so yeah its better but only to the point that its optimal damping rpm is well below what we run. remember calculated life at wot was less than 5%, mostly the motor turns under 3k as its a low/mid range tq monster.
also with as many outer rings ive seen seperate...id stick with sfi
