thats the low oil sensor. and why is it missing? that one is in the front of the oil pan, bumper side of the car.
the pressure sensor is in the oil filter housing.
Aeroforce can't read oil pressure.
Unless they have a special harness and add on for a oil pressure gauge. The factory pressure gauge on the oil filter housing is just a dummy sensor to let you know the motor is dead.
Oh brother.......So, I have no way of Knowing if the oil gets low........WONDERFUL........ "HALFASSERY" is THE perfect name!
BTW, I do not have a factory oil pressure gauge......
that sensor is not really needed, just check your oil often. the one in the front just tells you its low.
the pressure sensor that sob dont turn on unless its down to 5 psi or less, and its way to late by then.
Why not just be diligent in checking the oil once a week? If you have to rely on sensors for stuff like that, it will be too late to save it.
Checking the oil often won't always ensure you either, if the oil pressure switch blows out it dumps oil, and fast. So that's why I like it.
That's why I'm looking for some type of warning indicator..........
install a pressure gauge. you'll know when its a quart low just by looking at the gauge.
