Hid ?
Lil larry
I know you guys are tired of seeing hid ?s but I bought a set of 55 watt hid dual bulb set up and it has two hots and grounds so do I attach the ballast hot to the battery or the harness
If you hook your "hots" to the battery, how would you shut them off?
I was just wondering because it already has hids and there is hots already on the battery so I didn't understand
Then it sounds like there's a relay harness installed. If that's the case you'd hook the "hot" side of the ballast to the harness. Isn't that how the original HID's were wired?
