^ em you dk much about a retro d you
That wasn't directed toward you lol.
Alright, back about 2-3 years ago, I was in the same boat you are. I just wanted HIDs and not to spend a lot of money on headlights. Well I spent the money on HIDs...did I like them, yes, at the time. Then a couple months down the road I bit my lip and went for a retro, and honestly I felt stupid going with the HID kit first. The saying always goes, "Go big or go home". Ya HIDs are cheap and are better than factory, but if your going to spend money, I would highly recommend you spend it wisely. And as you said money is tight. My advice to you is save up and get a retro. I honestly cant express it enough. A retrofit is the way to go. Im not saying this to get your business, Im saying it to save you from doing what I did.
Yeah I think I would end up the same way, and I would really like to go for retros but it's the time/money constraint that has me even considering HIDs. And, no offense to you, but if I do retros I would really like to do them myself because I really want to learn about stuff even if that means messing up a little.
Can still get HIDs then go retros. Just when you went to retros you would need new bulbs and possibly a relay harness.
Sent from my HTC Thunderbolt using Tapatalk
Don't get the bi xenon kit for stock housings. The high beams are non existent.
ignore what I said about that HID kit, I guess they only sell kits with the goofy telescoping bulbs
So do you think these bulbs and new clean housings would be sufficient light output?
The relay harness is a hoax. You dont need it. Basically does nothing. Supposedly "saves" your factory harness. Factory already pushes out 12 volts to a bulb, whats the difference if it pushes 12 volts to a ballast?....Nothing! If the harness is free, then fine, its worth it, other than that, i wouldnt spend a penny for one.
So the relay isn't need then? Hmmm guess that answers my question too. So would a CanBus be needed to avoid 'bulb out' warnings?
-Brand new headlight housings
-H1 projector
-Mini Gatling Gun Shrouds
-Plug and Play wiring harness
$375 shipped
