What did you do to your Car today?
Status
Not open for further replies.
Found out my car won't remote start. Idk why. It just clicks. It starts fine using the actual ignition and the key fob works for locking and unlocking
changed my sc tensioner pulley today. just in the nick of time too, that thing barely spun. the bolt is normal threads for any one who want to know lol
JB weld on the rad is still holding up.
here's before.
first coat
final
used whatever his name was on here method with using a heat gun.. warmed the lights up first. light coat.. heated it.. heavier coats.. heat after each..
smelt up my whole dorm.. and right when i was heating the last coat my RA comes up the stairs.. opps.. sorry not sorry.. too damn cold out side to do it.. so now i got a fan in the hall and frabrezzing the **** out of the hall.. i love how they turned out though.
THis is a **** pic just cause the lighting is coming from the left so the right one looks bright.. i'lll stick them on the car in a little bit and take another one.
clear coat them, let them dry over night, then wet sand and compound the scratches out. will look 10 X better.
edit: just saw its a wrap, carry on..lol
if you saw my first post before doing it.. you'd know it's not a wrap.. it's VHT... and when i used the word "coats" ... c'mon scotty.. i don't have my clear coat or sand paper down with me at school.. it'll have to do for now.
New Valve stem with TPS is $62. I think ill just go with my spare wheels for now. Yay.
You can get it for ~$30 from Rock auto. Advance had the same one for $56, but there is a discount code on retailmenot that took $20 off a $50 order if you placed the order online and picked up in store.
also... discount tire has warranty if you got the tires mounted there.
That torque bolt snapped
Why's your supercharger look like It's covered in fire extinguisher foam?
Status
