Nchristopherson
I figured I would start a new thread for this since the old thread is irrelevant.
OK. So I did a camshaft swap on my car. Did the VS cam with SD Headers and a 3.4" pulley. I also replaced the front cover gasket, SC gasket, and LIM gaskets with the aluminum ones. New Autolite 104 plugs and OEM wires. I have not tuned the car.
When I first start the car, the misfires aren't bad, hardly even noticeable if any. Once it warms up, they start to become much more apparent, I can hear the car stumbling. Using Torque, I got the number of misfires for each cylinder, and cylinders 3 and 5 have by far the most misfires. 1 and 4 misfire very seldom. 2 and 6 not at all. Codes P0300 and P0305 (Random misfires and Cylinder #5 misfire) get set eventually. However, when the car moves, I get no misfires at all that I can account for. My OBDII software does not pick any up, the power is smooth and plentiful, and it doesn't set any codes.
Things it could be due to? :
Because the SD headers relocated the front O2 port, I did do a chop job on extending my O2 sensor, but it reads a full 0.1 to 0.9 volt range.
The car sat for 4 1/2 months and the fuel filter was changed 30,000+ miles ago. Possibly bad fuel? But again, the car has great power.
Leaking LIM gasket? God I hope not..that would be depressing.
Solutions attempted:
I tried to re-seat the injectors with lubing the o-rings and a rubber mallet, but that didn't seem to help.
Ideas:
Change the fuel filter
Do a compression test to check for just that
Fuel pressure test
Injector cleaner
Any information would be extremely helpful. Thanks.
Ideas:
Fuel pressure test
Injector cleaner
