I have a 2005 Grand Prix with about 140,000 miles on it. I have once in awhile smelled a slight antifreeze smell when I turn the car off but it is only about once a month for the past year. I have had to add a small amount ofantifreeze to the overflow tank about every 3 months.
I live in Alabama so it doesn't normally get too cold here but we had some very cold days this past Monday and Tuesday. On Sunday I added a small amount of antifreeze mix to my overflow to be ready and had no problems with the car starting, the temperature or the heat running hot either day. On Wednesday morning it was a little warmer and I drove to work about 15 minutes and the heat and car temperature were normal. I got to work and turned the car off and I had a small amount of white steam coming out of the front on the drivers side. I opened the door and smelled it and it smelled like hot antifreeze (not burnt). It lasted for about a minute and then stopped. At lunch I drove the car home, went through a drivethru and drove home with it. The temperature stayed normal and the heat was hot. I didn't have any smoke coming out when I stopped the car. I thought it might have been just a fluke thing so I drove it back to work and out last night without a problem.
On Thursday morning I drove to work again and again it was normal engine temperature and the heat was hot. But when I stopped the car it again had a small amount of white steam coming from the drivers side but it seemed to be coming from the firewall area. It only lasted about 15 seconds and I did not smell the hot antifreeze smell this time. I drove it home at lunch and no problems. I checked my overflow and it was full. I drove back to work and home from work tonite without any issues.
I'm stumped on what could be causing it since I'm not low on antifreeze, the heat is hot, and the engine temperature is normal. I have seen no leaking on the driveway that I can tell. Someone suggested the radiator cap to me but I'm not sure if that makes sense or not because I am not very good on diagnosing coolant issues. I did check all the hoses and looked under the hood for signs of leakage but couldn't find anything. I don't want to cause damage by driving it but I'm not sure where to even begin on finding the problem. I do not see any smoke coming out the exhaust and I see no signs of antifreeze in my oil. Any suggestions would be appreciated.
