kung fu panda (e85 with 2.8 )SOLD
Re: La Flama Blanca AKA Plastidip whip
some updated blower porting, gotta finish up outlet and polish inlet, but its pretty much done
filled silencer ports and finished outlet, used quick steel fyi to fill ports
Re: Kung Fu Panda NIC build,( E85 in the works, A/C Deleted)
How well did the Quiksteel work?? And are you going to use it to fill the EGR and the divot in the inlet?
I didn't think of that. and it works great! way better than job weld.
Gotcha. I'll probably be pulling mine tomorrow for the IC build, and grab some Quiksteel.
well almost have everything back together. but im missing my throttle cable bracket to my N* TB, so now i have to order one.
gotta plugs things back in and change engine oil and see what happens
still about a week off, bc i have to order that bracket, thought i could get away without it, but the cable binds up without it
Great port work man great!!! Dyno tune or no?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
will be getting a street tune from a local guy.
Ima head to a local dyno max out the most as I can loving your work you got coming 2.8 pulley is gonna s*** on some v8's man
Very nice work, so come on down to Fort Hood area and hook me up like that. ;)
how much should I charge for something like this? :-p
thanks. hoping everything turns out right when I fire it up. my main concern is the LS7 lifters. and vacuum leaks.
Vac leaks is always a pain at first startup well hopefully that's not a issue once you build compression you should be fine
I'm officially on e85 now. tuning through zzp, scanning and flashing with hptuners.
turbo tim sent me a base e85 tune to start with and we are scanning the car And I send it to him, he sends back the tweaks and so on.
I wasn't able to do a wot scan today. tires break loose on the highway now. it was damp outside. but the car has never broken the tires loose like that before. I'm talking just flat out spinning no traction at all.
car screams. I will post up speedo vids as soon as tuning is done and its nice enough outside.
also no KR on this base e85 tune either on the 2.8 pulley
