went in for state inspection and FAIL...
PaJeff
after replacing my FUBAR tstat I expected to find more poor mechanical work but took it in for inspection .I was pleasantly surprised to find new front sway bar,new cat and 02 sensor already had seen new struts and tie rod ends,new front brakes and almost no rust on the undercarriage.part of the brake line had been replaced around the exhaust tunnel and mechanic warned me to keep an eye on brake line by the fuel filter.rear brakes are right at 2/32s so I will replace those and the mufflers have started to come open at the seams.at least Im learning every inch of the car real quick
Wow, I'm about to get married and everything has been beyond great from the start. Although..I did wait quite a while and tried out a lot of the wrong ones before finding this one.
If you're giving her away that easy, I probably don't want her either.
not at all I have been fortunate enuff to be blessed with a goddess that it would be just plain selfish to not let someone else experience the magic that is her.......ur buying this right???
just wait does the phrase indentured servitude mean anything if not now it will later but congrats none the less Bill!!!
