Its not nearly as eventful as you think. On these motors the valve float will stop you from doing anything too dangerous.. Ive ventured pretty high a few times and its not all that insane. There is no reason to look at trying to put the mathematically wrong turbo on a motor and call yourself "smarter than everyone thats ever turbo'd a 3800".
Not at all what was said...
I had it on shelf, it would work pretty well. A stock 3.8 makes 200HP ! That turbo is perfect for engines making 140-200HP N/A
Sure it is on the small side for a 3.8 V6 but it will spool very quicky. There are better choices with larger turbines but not for me, it was free on the shelf. You are too sensitive and took the statement literally.
As for the 1100cc no one has made more testing than us. Nearly a thousand dyno pulls on many different turbo sizes for different application.
trail riding, drag racing, lake racing, top speed/radar etc...
Stock turbo, 2860, 2871, 3071, 3076, GTX3076, Precision 5830, Precision 5130, Precision 5530, VF45, and many hybrid turbos.
I know very well how to choose a turbocharger and what happens when you have too much turbo (Surge or lag) or not enough (Surge or extreme backpressure/low power output)
It always comes down to similar things.
A 3.8L V6 doesn't need as much boost to make 600HP, no doubt. Nor does it require the same turbocharger, no one has or should claim that.
A 3.8L needs a larger inducer on the compressor wheel and needs less pressure ratio ability than our 1100cc engine does. It also needs a larger turbine wheel because of the torque available at low RPM (Exhaust pressure)
