    TIPS:
Sale Ported exhaust manifolds for 3800 engines
t1264rk
I have a pair of front and rear ported exhaust manifolds, will fit supercharged and non supercharged engines, both have been welded and opened up, $180. shipped, i live in liberty center, any questions or for pics feel free to call or text me at 419-388-7825:th_shakinghead1:
What makes these better than regular manifolds? I haven't gotten a chance to look at a stock pair of manifolds yet but every post I've seen says there's not much room for improvement unless you happen to cut open the front one and hog it out.
The welding referenced is the improvement in the rear. The factory welding was done on the inside, causing an obstruction. If the outside is welded, the inside welds can be removed, to get a bit more air through.
The fronts are typically opened up with some sort of grinder.
these have been welded under the exhaust port, then opened up inside the manifold, rear has been done, but not as much as the front, if you take a look at a stock manifold, they are very restrictive
