Frosty
I Write E85 Stickies
So to preface this... I drive a e85 monster... in the land of -20* mornings.... It always starts but 8 second starts on really bad days do not impress the lady friend. On 30* days it takes less then 2 seconds and on normal warm days its instant so its pretty normal from what I gathered.
So onto the questions. One thing I have noticed with my lq4 maf (and stock) is that the first 4 cells or so are NEVER used once the engine is started. My question is does the pcm actually use the maf during cranking? Because if it does I was considering just bumping those first couple cells up a ways so that starts are a bit more quick in the cold... then as soon as it is firing on all 6 it should be in the normal cells and be happy as a clam... right? Or does the pcm just use the VE table during cranking? I know it takes a second for the hot wire in the maf to get "hot". I suppose if it does use VE I could just fudge the VE table a bit down low to get the same effect. Or maybe there is some crazy hard set cranking fueling that is only modified by the injector size table? Gm has done stranger things on these.
Yes I know this is the wrong way to do this but dammit hptuners wont let me touch all of the tables. Thoughts? Concerns? Food you'd like to pelt me with?
