The sensor picks it up and tells the pcm to back the **** up...So yes, it is real knock. There is a problem, in this case, the downpipe and swaybar hitting eachother. Fix that, the knock goes away.
Do you mean Knock Retard or actual Knocking occuring in the engine?
The KR is always real because Knock retard is the retarding of the timing that is occurring due to the PCM picking up what it believes is knock from the knock sensors. It doesn't matter what is causing it to pull the timing. If the PCM is pulling timing and reporting KR, the KR is real.
The cause for the KR can be false, as in the knock signal can be falsified.
Unless you guys have a different defintion of KR from say the GM service manual or the HPT manual.
Matt yes, that is what I mean
"These pressure waves force parts of the engine to vibrate, which produces an audible knock."
No where does it mention external factors that can cause the engine to vibrate or produce audible knock EX. metal against sway bar, exhaust hitting ect.
so umm go fish???
It sure in the hell is if the computer detects it and "believes it to be real knock" computers cannot guess things, its all 1 and 0's yes or no, real or not.
All that matters is that its being detected why is it so hard for you to grasp it doesn't matter if its internal or external??
I think the argument now is 2 sides of the same coin...
Youre both arguing 2 different things but are making the same point lol...
Anyway Chris, now that you have the fuel pump fixed and a tune do you notice a difference in power with e85? I filled up the other day at $2.69 a gallon with a smile on my face :th_thumb-up:
Apparently google has 23,300,000 hit for san squash
Apparently google has and 85,800,000 hits for aliens
So no god damn it were not done............
Believe what you will but by your thinking san squash and aliens must be real too????
I like it so far, although my gas mileage has gone from "decent" to "crap". The car definitely feels like it pulls harder, however I really need to drop a couple pulley sizes to really take advantage of the stuff. I'm still rocking a 3.0 for now.
Yeah you will get a couple mpgs less with e85 but with the fuel costing less it evens out. Post up when you drop that pulley and let us know how it goes. I'm trying to decide what to do next on my car because the trans should really be next but I really want to port the blower and get a N*. The trans is fine now but I know adding all this power will kill it. I'll do both eventually but can realistically only do one or the other this winter... You are on a stock trans too right?
Yessir, stock trans and still doing just dandy. I'm going to start piecing stuff together for a new trans because I know one day the stocker is going to go boom. I'm on borrowed time lol. I wouldn't waste your time and possibly $$ porting a gen 3. Just get a gen 5 and be done with it. You'll thank me later
