Best fuel pump.
Sudden
I can see bigger injectors coming next spring. Is there a fuel pump that is a nice drop-in that will assure i have plenty of fuel for the future?
For E85 or 92/93 ? For E85 I'd do the AEM pump, or the racetronix. Otherwise it doesn't really matter for 93... Aeromotives are very hit or miss though, as is the ZZP pump.
I would have to cast my vote for the Racetronix pump simply because it is so widely used and proven to work.
It's for 93. I was hoping to find a pump with a great reputation that just dropped in. I looked at the Walbro, looks good, but doesn't just drop in.
I don't think any aftermarket pumps just drop in. You have to re-use the canister, wire them up and install the fuel line. I bet you could just install a hotwire fuel pump wiring kit, change the filter and go with 42.5 injectors and not run out of fuel with a ton of more mods and 93.
I'm begining to see that about the drop-in. I was going to do a hotwire, but with a 2005 there's no door. So, I thought I'd do a pump at the same time. I'll probably go with the Walbro, it looks very good. I'm just lazy and it takes me time to accept I have to do a little work. :cool:
ugh i had to replace the fuel pump on my 97 tbird... exhaust drop tank drop and then they reused the seal so it smelled like gas inside the car (no go with a 3 year old) so i made the shop drop everything again and replace the seal. so glad my 01 has an access door, its the way everyone should have went from the factory
