Also got some new toilet plunger heads.
I really don't want people looking at this and really believing that's what they are, they're cv boots lol
send me those along with your axles
Lookin good! Did you use VHT for the tint? My turn signals are in desperate need of this.
I would consider getting one or renting one. I've tried using regular tools and could never get the clamp tight enough.I don't have the special clamp crimping tool, but it looks like I can get away with the basic tools I do have.
why don't you just get switch backs..... c'mon...Lookin good! Did you use VHT for the tint? My turn signals are in desperate need of this.
They're a beauty, aren't they? lol I've seen some really bad dry rotted tires on someones car on these forums. So bad it's a large crack going through it. Where did the batman part come from?
I'm getting new ones before winter hits. They're only 5 years old and already dry rotted. I blame the previous owner, he must have used some crazy strong wheel cleaner all the time.
Also replaced power steering return and pressure lines. now my pump is whining and drawing too many rpm's at idle... i think its bound up
jack the front wheels off the ground, car off turn the steering wheel lock to lock 10 times or so, then fire it up, do it again, this should purge the air out of the lines.
That's a lot of holys
Went crazy cleaning my rims up really good. I figured since the torque stars show so much past the face of it, I should really clean the whole rim. Much better now, you really see it too, even on the car.
Before
Before/after. Just cleaned with dish soap.
Dish soap worked well, but not good enough, so I bought some wheel cleaner. I've been using car soap so far on the rims whenever I'd wash my car. I only used that much after applying it multiple times to both front wheels.
Much better.
You can really see the difference. If I was able to take a picture in direct sunlight you'd really see it.
I also waxed them inside and out before putting them back on.
Wow those look great! I need to do that to mine.
