Thanks. Im sure it will end up with a wing eventually. I went with the vs because someone I know had one and he was really happy with it. Also I already had the l76 springs installed from when I did the rocker so I didnt have to buy or install new ones. The car pulls good and I would do it again. The only thing I miss is the lope from the bigger cams.This car is gorgeous. It is screaming for a Gen 1 wing though.
Why did you go with the VS over other cams? Drive-ability sake?
Just out a Pontiac sticker over center capThanks man. The pony is actually raised so I need to grind it down, build it up, or get different caps.
If I can't make mine work I will go this route. Thanks.You could also do something like this...
Black Aluminum Mustang Center Cap (Large Size) at AmericanMuscle
Then get overlays from reflective concepts.
Thank you.Nice car
