Gtx has a turbo!! lol
Re: started tear down of the 01 motor
Lol what would I do without you guys, thanks so much I think I can use my gaskets again but might go with new to be safe, im going to sell my heads I pulled off to this kid doing a top swap im going to give him most of everything for 360, so that should help out with the build to get more parts I need
My cell tweaks out when I load photos, but top one is off the motor that im selling, the silver ones are the ported ones
Could of but...
To much effort for little gain and I rather help someone out then make a few bucks profit. Now you should have it together quicker.
Could of but...
Lol good man yeah its coming along now just need to wait for money and parts I can't wait:)
NIC cam, 130# springs/retainers/locks, LS7 lifters, Rollmaster Double Roller timing set with machined oil pump cover. All with less than 7k on them.
Would it be worth 675 plus shipping?
I would go cheaper then that simply because its used and a package deal should save you more vs them parting it out and possibly sitting on parts until someone pays their asking price.
What would you pay if you where to buy it?
I'd go in with an offer at $400-450 to start with since they are used parts and its all together in a package.
Re: motor pulled from 01 gtp for my nic build lots of pictures
OK here are some pictures of everything I removed
A
This is the bracket to the a/c compressor there are three bolts on this side and 2 on the bottom
A
disconnect all the sensors and plugs any vacuum lines
also don't forget the fuel lines
here's some plugs by the power steering under the car that you have to undo
undo the lines of the transmission
undo the motor mounts I forgot to take a picture of the other side its underneath of the car on passenger side just two bolts on each side
I just undid the bolt on the tie rod and the center one because I'm parting it out but it can mess up your alignment if you don't have it straight When you put it back
dick fingers omg!
Other motor pulled
Meeting its new home for now ;)
Resting in its mounts
when I get off work tomorrow I'm going to put the exhaust on And connect everything, I put in a new trans filter as well also broke my neutral switch on the trans so I bought a new one Can't wait to get My SSC springs 1.8 drop and 1.6 what do I need besides anti Pogo washers
And might get tog headers what do you guys think
make sure you get atleast gr-2's otherwise your going to bounce in the front........
These! I probably wouldn't go over $500 or so. If he wants it sold and quickly he"ll come down if not then he can deal with parting it out and then sitting on them for however longs. Look at it this way you have no way of knowing how many miles are on the cam, lifters, chain etc so you'll already be taking a chance.
Thats what I told him I was like yours has miles on it so I need a better deal the a 160 bucks off of what I can get for it new lol
