MoarkatsINmuhtrailer
Bottom end don't matter Eddie, turbo>blower any day
That is very debateable as people have used both with excellent success. However, logic would reason on the side of choosing an engine that is designed for boost.do you get better turbo results with a na or a supercharged? im thinking about buying a newer grand prix to turbo.
Yes it was worth the money IMO to turbo the car. It drives differently than a blower GP and the power is continuous now even in the upper RPM. However, I always say if someone is going to be happy with 12's then don't waste the money going turbo. The only way I would recommend someone going turbo in a GP is if they are just wanting something a little different with the possibility of going for more power at a later date. If you add up the cost on a S/C build to get the car to low 12's-11's then you will quickly find out its more cost effective going the turbo route. Many times the only reason someone stays S/C is because they cant afford the large chunk of money up front. It's cheaper for them to spend a few hundred bucks here and there than save for awhile to go turbo. By the time they get to the point of finally realizing turbo would have been a better choice they have already spent gobs of money.in your opinion was it worth the money to turbo your GP? curious because i have diamond pistons and may possibly go turbo in the "future" depending on how much i like my GenV IC set up.
well, you'll have to pay import fees if you do. Might as well buy ZZP for that reason alone.
pretty sure thats only like $25 correct me if i'm wrong.
The waste gate placement is terrible on the CT kit. When I purchased my CT kit used, it came from Canada and I still had to pay an additional $125 when it was delivered. If you are seriously planning on spending that kind of coin on a turbo kit do a Z7 or Stamatta kit from ZZP. Or better yet spend around 3K and get you a used one.hey new to the site, and have been thinking for about a year about dropping some money into my 04 GP. Was looking for some input into the current setup they sell for my L26.
Cartuning Performance
Including the methanol injetion, intercooler, electric cutout and ceramic coated stainless pipes this kit runs about 5700.
Anyone have a similar setup/ different ideas/ things they would of done different?
Regardless what it is. I'll take a z7 kit over a car tuning.
If you have a turbo kit please post your mods and any dyno results. I would like to start adding others at the bottom of the first post.
is the northstar maf and throttle body ok to use with a turbo? currently supercharged with an a/w intercooler and N* tb/maf and am wondering about compatibility.
