rpenlington
Hey guys,
Ok so, my saga with my '03 GP 3.8 n/a continues. I bought an 06 GXP about 3 months ago and the '03 has been mostly sitting although I have driven it a few times just around town. Long story shorter, after having my upper intake plenum replaced I noticed a sqeal to the engine which I suspect is negative crankcase ventilation (other post: http://www.grandprixforums.net/bad-...intake-plenum-replaced-79004.html#post1062466). Havent determined whats up with that.
New problem: I started up the engine to work on it Sunday and after it warmed up a bit I noticed that it was smoking oil (pretty sure) from the front of the engine. Looked like a big oily mess and I could see oil bubbling and burning around the front exhaust manifold and under the rocker cover was dirty. So, I pressure washed everything and then replaced the front cover gasket. Ran it after back together and was still burning, from down in the exhaust manifold area. Let it run about an hour..it *finally* got to the point where it didnt look like an issue, smoke was barely visible if at all -great issue fixed.
Test drove it around the block a few times..seems fine..gave it a little shot of gas, up to 60-70km/h (30-40 mph?) and I could smell it burning instantly at that speed with the window open. Hung a right and back into my block, into the driveway, smoke coming out under the hood (I wont say billowing, but..some might, it was definitely burning something fierce). Turned it off, popped the hood, smoke everywhere out of the front exhaust manifold area. I cant see any leaks from the top and it looks like my gasket repair is fine. It doesnt overheat, doesnt appear to be a head gasket issue. I just had the UIP replaced and new gaskets, egr, etc...
W..T..F..
Help please this was supposed to become my winter beater and I've put a good bit of money into tires, brakes, engine maintenance, etc. The trans isnt shifting very well, rough jumping in and slow to gear up sometimes but I might be able to buy a little time with an oil flush and some additives in it. I'd really like to keep the car going - love my GP's
Thanks guys,
Ron
W..T..F..
Thanks guys,
Ron
