What did you do to your Car today?
Status
Not open for further replies.
Washed my car today, washed her last Friday and discovered a water leak from the dome light.
After doing some research on here discovered the On-Star antenna could be the culprit, sure enough took the head liner apart and put some silicone under the antenna, tightened it up and wallah (or voila if you're French) no more leaks.
Tried applying 3M to HD lip...just as before it does NOT stick to the material hardly at all. Maybe this is too hard and rubbery and not foamy? I have another one thats much softer and foamy, but I don't think it will hold shape at highway speeds but it does curl around corners and stick to the 3M. Not sure what to do
Edit: put the foam one on. Didn't take my time so it looks like ****. Oh well, I'll redo it at some point.
Pics of it on ur gxp?
Status
