how does this idea sound for exhaust mods
kking89
I want to get a 3 inch bolt it DP with Cat from ZZP. Then I plan on getting Magnaflow mufflers. And ideas anyone? Does the DP sound like a good idea. Idk if I should get a Shorty
a shorty you'd have to do some welding.
skip the cat if you can get someone to tune out the code.
the exhaust sounds like **** whatever you do, keep the stock mufflers.
just get one dont go for the stainless no benefits. and get the pre paid label in option 2. you send back your stock dp and they will give you a $50 coupon
im still a little confused. will that down pipe throw any codes? also can i send it to them after i install the new down pipe?
Or you could do what they have convinced me to do. I was looking at the same downpipe with cat but I found speed daddy headers with a downpipe for only 220 shipped to door.
offer them 200 they will take it. but then also get a high flow cat for like 70ish dollars along with a o2 extension and double walled flex pipe if you go that route
Alright I'll try offering 200. And I have to get a catalytic converter with it?
i heard with speed daddy you need to do some modifications to the headers to make them fit
Sometimes. They're hit or miss is what I've heard. I know a guy that's installing mine for $200. Not bad at all if you ask me I just want it done correctly. I'm doing the rest my self
