92bird
I've tried running their 10.3mm wires, and the car misfired under boost so I exchanged them for a set of their new 10.5mm wires. Now the car will barely even idle. I triple checked the cylinders and they are all hooked up correct, plug wires clip on nice and tight both at the spark plug end and coil pack end. I was impressed at how nice and positive then clipped on actually.
So I remove them and toss a worn out 30k miles set of autolite professional series stock replacement wires back on and it runs perfect..
Do the bigger wires require a stronger coil or do ZZP wires just suck?
My ICM is new, and I tried the coils and ICM off of another car. Same result. Stock wires work fine, ZZP wires the car doesn't want to run smooth at all.
I'm just wondering if there is a problem with my ignition system, and maybe the lower resistance wires are causing the problem to surface.
Thanks for any ideas..
