    TIPS:
Sale Comp cams 1.9 roller rockers + springs, seals, retainers.
apierce1289
South Hampton/New Hampshire
Like it says I have comp cams 1.9 roller rockers. Also comes with zzp modified retainers and viton valve seals. Crow #105 springs come with these as well as reusable bolts.
Make me a reasonable offer. Just need to get rid of them cause I'm changing my build. Asking $350.
Sent from my XT912 using Xparent Red Tapatalk 2
4. CITY / STATE are required info for each ad. Buyers and sellers reserve the rights to privately ask for full contact information on any purchase or sale. 24 hour notice will be given, if you do not comply your post will be DELETED.
Monkey you are slipping.
2. PRICE IS REQUIRED. We do not permit ads without an asking price for each item. "Best Offer" is not an allowable substitute for posting a price. You may ask for $1 but a price must be listed regardless. If a price is not listed with in the first 24 hours of making your sale thread IT WILL BE LOCKED or DELETED.
Yeah I got these still. Pm me and I'll give you my cell and text me tomorrow for pics ect.
Did you notice a pretty good difference? I was looking at 1.8s but people were saying the roller 1.8s are actually less performance than stock?
I actually was planning to put them on but never did. Bought them off a guy on here and got the things I needed but decided to go turbo and ported wbodystore heads so I'm putting the money towards that. The heads from wide body store come pre built with everything except rockers. And the Cam I want wouldn't do good on 1.9 rr so I'm getting sock ratio roller rockers for my turbo build.
Sounds like a pretty fun build. Big fan of turbo swaps , so I'll be looking for a thread in the near future. :)
And keep me posted if you still have them.
i port and polish heads. ill post some pics of heads i do. flow a bit better than stage three heads and with better scavaging like the indy designs. im running 16/1 on pump gas with no spark knock. ;)
Oh and btw the parts listed are spoken for. Just working out the details :)
Depending how involved u want me to go and if ur supplying uncracked heads. Just pm me with ur info, what u want, what lift, bigger valves, and what not, if u want a figure. the 08 g6 Set I'm doing now stage 3, larger valves, 3 angle grind(better heat transfer), high lift, cylinder wall matched, deshrouded, springs, and drilled tapped for 10mm bolts cost right around 1000.
