There should be a sticker, I think on the strut tower(???) that shows how many pounds of coolant it takes for a full charge. But seems like they later had a TSB issued or something that upped that number a bit so probably google it to be sure. Or get T.I. To look it up on his GM computer at work??.
I found it, just was wondering what others experience was, it cool enough, just could be a little colder, not worth busting open a partial can though.
[Edit]
I will add pix from my strut tower.
I found this chart
http://www.techchoiceparts.com/refrigerant-and-oil-capacities
Here is the GP section....
[TABLE="class: fluid-capacities, width: 672"]
[TR="class: fluid-capacities-model, bgcolor: #E6E6E6"]
[TD]GRAND PRIX[/TD]
[TD="colspan: 4"][/TD]
[/TR]
[TR="bgcolor: #F3F3F3"]
[TD]2004[/TD]
[TD]All Engines[/TD]
[TD]
R134a[/TD]
[TD]37.00[/TD]
[TD]PAG 150[/TD]
[TD]8.00[/TD]
[/TR]
[TR="bgcolor: #E6E6E6"]
[TD]1998-2003[/TD]
[TD]
R134a[/TD]
[TD]36.00[/TD]
[TD]PAG 150[/TD]
[TD]9.00[/TD]
[/TR]
[TD]1997[/TD]
[TD]
R134a[/TD]
[TD]36.00[/TD]
[TD]PAG 150[/TD]
[TD]8.00[/TD]
[/TR]
[TD]1994-1996[/TD]
[TD]
R134a[/TD]
[TD]32.00[/TD]
[TD]PAG 150[/TD]
[TD]8.00[/TD]
[/TR]
[TD]1992-1993[/TD]
[TD]R12[/TD]
[TD]36.00[/TD]
[TD]Mineral[/TD]
[TD]9.00[/TD]
[/TR]
[TD]1988-1991[/TD]
[TD]R12[/TD]
[TD]36.00[/TD]
[TD]Mineral[/TD]
[TD]8.00[/TD]
[/TR]
[/TABLE]
Looks, like I may be a can shy?
[End Edit]
That blower actually looks pretty decent, the more black coating the better. Don't ever try to clean the blower pack or inside the case, that crud give it a better seal for more boost. I've seen them come outta cars completely silver and shiny, but it's usually flakes of the black coating that's more common. So pretty well anything that still all black like that one is good. Just look at bearings for sings of heat. And twist the pulley back and forth real quick, you should feel some slop(looked at probably 50 blowers at pullapart, only 1 wasn't worn) which is a worn coupler that's cheap and easy to replace and swap blower oil same time.
It maybe hard to see in the picture, there were some groves around the outside blower case, and if you look real close there were some on the blades. That was the part I did not know if normal. I figured someone went through the effort to pull it, then abandoned it. Almost makes me think if it is all still there, might go get it. Bad thing is next Saturday, I have a funeral to go to. Doubt if it will all be there in two week. :-( Thanks for the coupler heads up, that the kind of information I need. Just more of it.
I personally would do a little more research on what it takes to convert to a 65 just to be certain, then decide what to do. I hate tossing working parts so I'd probably rock the 60 til it blew just cause then swap a 65 in. Unless its too big a pain to swap, then I'd just ditch it now lol
I agree. Before I spend big bucks, on something I don't think I can get my money back out, I will make that decision. Need to do more googling, unless someone who has done it can jump in.
Was your 06 same color interior? Leather? I think I've seen it but don't remember... Those seats from the newer ones will fit 97-03 too, fronts direct bolt in, backs are a little mod but easy. Then wire then up of course, which I've seen write ups on. Just another thing you might buy the wreck 06 back for maybe.
It was cloth. They want almost $1600 for the salvage value. My cousin had a salvage license, need to ask if he keep it up, they are so hard to get I know for a while he was. I may find when it goes to auction and see what I can get it for. I would like to have a bunch of parts for the new 06. The interior is good, but the seats in the old were better, I had put new bakes, tires, wheel bearings, and such.
