this site is more geared towards the 97 and up grand prix's and w bodys.
your car is totally different platform.
on the up side thats low miles. dont know what engine you got, but if its a v6 you may want to drop a v8 in it. unless its a grand national of course, then you got yourself some thing to work with.
if it has not been ran in 9 years, you should pull the plugs drop some tranny fluid in the cylinders, then grab a breaker bar and socket to the harmonic balancer bolt, and turn the motor by hand a bunch of times, then use the starter to crank it some more, no longer then 15 to 20 seconds at a time, or the starter can burn up.
then pop some new plugs and wires on. check the air filter, change it if id needed. change the oil and filter.
if theres gas in the tank still, that needs to sucked out of the tank, the fuel filter changed, fresh gas added, then fire it up. let it idle for a while before revving it up or anything. the cranking of the engine should have primed the engine oil , aka got oil to the top of the motor, but being its sat for so long let it idle and oil its self up.
depending where this car has been sitting mice may have moved in and chewed wires, that may have something to do with your power issue. so look over as much wiring as you can under the hood and under the dash, if you see a lot of crap packed into a area you found a nest. and mice make the inside of the car smell like crap. you know is mice once you've smelled it before. its nasty.
