Keep in mind..block the wheels on both cars.. set parking brakes etc. Then slowly use a come along that is strong enough and some serious straps or double/triple them up. I was concerned the whole time I was pulling that the straps or come along may break while I was doing it. Go slow, then undo pressure and measure..go a little more..undo measure. Yes you can measure from points like bolt holes on a good one at any yar or if a buddy has a GP. If you hear any bad noises..run ...cause snapping metal cable hurts and takes longer to heal than looking like a wuss running away.
That car had sat for a couple of years in a barn. Mice had built quite a house in it.
Ok.. let me give you more detail.
I have these tie down ratcheting straps..they are about 2inches wide. Similar to these..just older 4 Race Car Hauler Ratchet Tie Down Straps Axle Strap RD | eBay
Now.. take your car and put blocks in front of each wheel. Back the truck up to it (say about 4-6 feet between them) and block the trucks wheels..except.. put the blocks behind the wheels. That way each vehicle is blocked from pulling toward the other. Then I put the come along hook onto/into the trailer hitch of the truck. After that..it was positioning and using the come along to pull. If there is a sharp edge where you are pulling..use something like a rag to cushion the sharp edges.
I pulled mine. Aha still have more to go. But its enough to fit for now. I used 2 heavy duty chains.lol
They would probably be better than chains cuzz thechains I used werekinda big amd likedtoslide. Altho you don't have tobeafriad of the breaking lol
Sounds like it's coming along. FWIW I try to find parts in the right color based on not having to paint.
My radiator support is still, bent upbaddd.but ineeded, it running ao I slapped it togethrr. I have no ac cuz I didn't get a new acocondensor. I've had the p0102 code. And I put an hai on yesterday. I decided to take My iac out to look at it andnthe2 small bolts broke off and r stillin the tb. So I gotta go to the jy tomorrow and I'm gunna find another tb, lol and get a new iiac as well. I've been riding around with just my front bumper ( no supports lol. ) my right headlight bravkets bent a little. So its a little off. But its Pos when I get a job I'll fix it all over time.. but for now itruns at least. ( gold car with black front bumper and a black hood with white racing stripees (; lol )
Damn nice job on the core support!
