2nd tranny cooler questions...(2006 GXP, ram hood and cai, 53,000km)
Ben10125
Ive heard alot about having to put a second cooler in and i was wondering if someone could explain what happens if i dont?
I was also wondering if there is a detailed video or description of how to go about adding one and the benifits for having?
let me know
thanks Ben
May be wrong thread sorry im new here..
Also I'm planning to make a super detailed how to some time this week when I install mine.
But their not hard to do
umm, i drive in the city 2 days a week res is highway... also what would a high tranny temp be in celcius? ive it 101C
101°C is 213°F which is hot. The temps u wanna see are like 170°F-190°F which is 76.6°C - 87.8°C
ok so i should get that done right away... should i tackle myself? like do they sell bolt on kits? or should i bring to shop?
They sell bolt on kits. Go to tripleedgeperformance.com and they sell kits with brackets but the kit I just bought is a complete bypass (meaning the stock cooler will no longer be used)
I will do a good write up hopefully next weekend when I install it that u can use
I would do the tranny cooler before any other mods but people go all the time with out one
thanks, so if i add another cooler do i just rune the lines into existing cooler lines( supply and return) just to technically give it a bigger rad? or pipe right into tranny?
If u just got an extra smaller cooler than u could put it so that the fluid goes to the radiator then to the extra cooler. U just cut the stock lines and add it in. But if u got a big enough cooler it'd be better to by pass the stock cooler
With him being in Canada where the winters are a little more harsh, would he be better off running a smaller cooler inline with his radiator cooler? If 213* is as hot as he's gotten, I'd suggest the smaller cooler. It should knock the temps down the 10 - 15 degrees he needs while helping with the warm up on sub freezing days. Might want to invest in a TransGo shift kit to. It will help with temps. I installed mine (still on my factory cooler, but V6 car) and I instantly saw a 15* reduction in temps while climbing my mountain going back home. I'd see upwards of 232*, now the hottest I've seen was 213* climbing behind a slow moving truck. Plus the shift kit will help trememdiously on wear and tear, not just a performance add on.
I'm with marines with suggesting a large cooler to bypass the stocker, but this is just my $.02. Just something else to think about if it's his primary driver year round...
Well if he got a cooler like mine i just got is what id recommend. It does do much cooling until the temps get higher and the fluid gets thinner. It in the design of the cooler.
I can't remember what exactly this type of cooling is though
Part Number?? :D
And I'm really looking forward to the writeup you do!!!! I will be doing this soon and probably adding fans.
