ericspecullaas
found this lol have no clue if it will work
Perform the following steps:
Sit in the vehicle driver's seat.
Remove the ignition [COLOR=blue !important][FONT=inherit !important][COLOR=blue !important][FONT=inherit !important]key[/FONT][/FONT][/COLOR][/COLOR] from the ignition lock cylinder.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and [COLOR=blue !important][FONT=inherit !important][COLOR=blue !important][FONT=inherit !important]Chassis[/FONT][/FONT][/COLOR][/COLOR].
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Remove the ignition key from the ignition lock cylinder.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System [COLOR=blue !important][FONT=inherit !important][COLOR=blue !important][FONT=inherit !important]Operation[/FONT][/FONT][/COLOR][/COLOR] .
Important
