'99 GTP. Infiniti wheels. How big do I need to bore to clear hub?
Blake71091
The wheels I have from my old car have the correct lug pattern, but a hub center of 68mm. How big should I get the hub center bored to?
I know our cars are about 70.30mm hub center size.
Do I machine them to 70.4mm or 71mm?
Thanks.
Stock wheel hub bore is 70.30mm, so I would think you'd bore them out to that for a good fit and not have to use hubcentric rings. Why go bigger than needed?
Question is, what is the offset and size of the wheels from your old car that you are thinking about doing this to?
18x8 30mm offset 2004 Infiniti G35 Coupe wheels.
