Does it make sence to add larger fuel injectors on light modded GTP for a HP gain ?
JT2002GTP
Just curious if you can gain better performance by adding larger fuel injectors. If so does anything else have to be added along with them, like higher volume fuel pump or whatever. Thanks.
the injectors don't have to be completely static to see gains from larger injectors. some injectors have a better spray pattern and mist the fuel better. id say if you are at 85% or more its time to upgrade.
115% is a good time to upgrade, assuming you want to push it more.... otherwise why upgrade.
