TwinV6GTP
I'm tuned for 15.5 A/F highway lean and it likes it, no misfire.That is nuts. My regal only gets 18ish city, and 28 hwy current setup
More timing than stock.
iirc mine is like 14.6 hwy, You should build a budget 3800 Fiero like this, guarantee you will pull flat 10's.
Being that you prolly didnt adjust the tune, its always trying to achive stoich, so 14.7 but the numbers are always jumping around.
All the easy weight reduction is done. The hard stuff has a lot more to do.May I suggest a free mod .......................
Gut that slut and see what she runs!!!
Ohh and some real tires like you already mentioned
Not sure what you mean ?Do you only do this on the track?
Thanks, I have found a before and after of 30 crank HP from stock to XP cam. That is pretty significant.I don't have a before and after but after putting a set of p&p heads, s1x cam, and headers on my car it's a ton faster.
Anyone ever did a before and after Dyno with just headers ?
Or before and after Drag E.T. ?
I'm curious about the real world gains...
When I made my 3" cat less exhaust it made a huge difference. Night and day.
My logs showed a lot of power and was all stock pulley. How much more power would a header give me.
The way I see it, most people when installing headers also get a full exhaust so who knows which gives the most power.
Also same idea with a cam, I was hoping to stay stock idle, stock sound... but if I have to go in the cam, I will. I need more MPH 110-112 + with just one engine for my goals.
So before and after cam dyno or track E.T. etc...
In the meantime I'll see what I can find with a search.
I drive it to the track, no street race, just some on ramp accelerations here an there.He's asking if you street race it most likely.
I run AV gas 100LL all the time which is a little more expensive than pump.Do you run all the meth and e85 or whatever and all race gas on the street daily driving?
I need them to be streetable. I think M&H are the best slicks out there, perhaps the best DOT radial as well.If you get slicks go for QTP's or something sticky. Ive got the 255 ET Street radials, their nothing special. Better than all seasons or nittos but still not a real slick. Best I got out of them was 1.88 60' even with the cables on. That was launching at about 1400 rpm and rolling into the throttle until 2nd. I do have 3.29 final drive too though.
I can, I have stock brakes but with a second engine and 130mph+ trap speeds which are a goal for this car, I think they will have a hard time stopping the car at 4100lbs !!M&H doesnt make a good size for our cars that I can find. Unless you can still fit 15" rims in the front. I cant with F-body brakes.
