If you are running deep into the 12s on 1 motor, I think its still a bit of a stretch to say you would go deep 12s with a second. I say this because that is claiming a full 2 secs on a AWD change. Now granted, you should be able to pull off the line like a rocket, but I would say at best you go from a 2.0 60' to a 1.5 60' which would at most save a full second off the 1/4 time and that is to say you don't shell one of the trannies in the process.
I get the calculation that the AWD power/weight ratio will be much different, but you are also talking about the motors being different power figures, unless I missed something. You would have to have both motors built identical, making the same power, and the trans geared the exact same and able to handle the power/torque of the motors or once you get moving the 2 drivetrains will be fighting each other and that will slow you down. Could be cool, front makes 300whp and pull the car, back motor makes 500whp and smokes the tires the whole way... but you'd still only go as fast as the slowest motor could pull the car, or you'd break something along the way.
Same reason why front and rear differentials have to be the same on a 4x4, the transfer case would shell due to them turning at different speeds with different force. Everything has to work together.
Just my 2 pennies.
Still hoping for a Snowflake TVS WTH that is awesome, congrats result once this is all done. (long story)
