See post 51. It's a track run, and the exhaust is pretty quiet.After 5 pages and still cant tell if trolling or not....
Where the vids and pics at, ever get that exhaust clip up?
Come on now, what else do you need. Just read what I wrote, no one could come up with that.After 5 pages and still cant tell if trolling or not....
It probaly isn't restrictive enough for the cut out to be worth it. Unless you like loud when racing.This exhaust + a cut out...What more could any 60 degree 3800 owner ask for?!
I'm injecting in the plastic vacuum port via an adjustable electronic methanol injection kit.So your able to run this super small pulley by using meth and c16? How do you have your meth injection setup?
We could make a certain number of exhaust based on a popular 3" downpipe. It would have to be a 5 piece minimum order (group buy)Ever consider making a "stock shaped" exhaust with those res/muffs? I would REALLY be interested in a 3" (with a 2bolt 3" flange to fit my 3"dp) back to 2.5 muffs system for my turbo GTP. If you ever would think of making one, how much would you charge?
Right now it is rich. I have tried leaning out to 12.0 when I had C16 and meth.Wehlp, that explains that.
10.x AFR.
Yes I know. It's the extra cooling that is not a bad thing when 1st testing a new tune.AFR's that rich aren't great...Fuel washing the cylinders isn't good for the car either.
Leaner AFRs when combined with knock aren't as forgiving.
I'll tune it for around 11.5 which is a good compromise
Let me know what pulley you can get away with on that AFR and pump gas.
I'm guessing a 3.4"~ or maybe a smidge smaller.
