    TIPS:
SOLD Delete please!
Status
Not open for further replies.
Re: 1988 Pontiac Fiero Formula, built 3800SC swap
eBay buyer did not come through... Cash in hand price is $3500 until my eBay dispute is completed, then the car will be going back to auction. I will post more info here later!
[TABLE="class: vi-vs-cntHt"]
[TR]
[TD][/TD]
[TD="width: 27%"]Vehicle History Report Summary
VIN #:1G2PE1191JP205651
Report Run Date:Apr-24-2013
Provided by AutoCheck, a part of Experian. Copyright Experian Information Solutions, Inc. 2010. All rights reserved*[/TD]
[TD="class: vi-vs-varSpc"][TABLE="class: vi-vs-vhrHt"]
[TR]
[TD="class: vi-vs-rtBrdr"][/TD]
[TD="width: 50%"][/TD]
[/TR]
[/TABLE]
[/TD]
[TD="class: vi-vs-pt6, width: 35%"]Highlights
[TD="class: vi-vs-tpBrdr vi-vs-padTopBtm"] Title Check: [/TD]
[TD="class: vi-vs-tpBrdr vi-vs-padTopBtm, width: 30%"] OK [/TD]
[TD="class: vi-vs-tpBrdr vi-vs-padTopBtm, width: 30%"] Odometer Check: [/TD]
[TD="class: vi-vs-tpBrdr vi-vs-padTopBtm"] OK [/TD]
[TD="class: vi-vs-sctb vi-vs-padTopBtm, width: 22%"] Accidents: [/TD]
[TD="class: vi-vs-sctb vi-vs-padTopBtm, width: 30%"] None [/TD]
[TD="class: vi-vs-sctb vi-vs-padTopBtm, width: 30%"] Owners: [/TD]
[TD="class: vi-vs-sctb vi-vs-padTopBtm"]3[/TD]
[TD="class: vi-vs-sRpt, colspan: 4"] See the full Vehicle History Report [/TD]
[/TD]
[TR]
[/TR]
[/TABLE]
[/TD]
[TD="class: vi-vs-pt6, width: 280"]AutoCheck Score
[TABLE="class: vi-vs-pb2 vi-vs-sctb"]
[TR]
[TD="class: vi-vs-scr, colspan: 3, align: left"]
26​
[/TD]
[/TR]
[TR]
[TD="align: center"][TABLE="align: left"]
[TR]
[TD]
[TABLE="class: vi-vs-bwz"]
[TR]
[TD]Below Range under 13
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD]
[TABLE="class: vi-vs-rbox"]
[TR]
[TD]Within Range 13 - 37
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD]
[TR]
[TD]Above Range over 37
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD="class: vi-vs-rtxt"]
Within rangevs. similar1988Sport Car -​
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
This is my 1988 Pontiac Fiero Formula Edition, with a 3800 Series II L67 V6 motor swap, she is my baby! They made less then 6,000 of these cars making it pretty rare, and as the days go by, more and more collectible! The motor and transmission are from a 1998 Pontiac Grand Prix GTP, that had roughly 40,000 miles when pulled. This is a "project car" and is CURRENTLY NOT DRIVEABLE! I purchased the car from the Original owner family (Father and son owned prior to me). It is a born and raised Georgia car with ZERO rust on the cradle or body, the only rust to speak of is some very minor surface rust on the battery tray. The tires are older, but show no signs of age, very sticky Yokohama AV1-60i with almost .300 tread left (over 1/4inch, almost like new). The battery was also new last year. The car has AC, but the system is not hooked up. The headlight motors work, The power window motors also work, but are slow. The paint is original, has plenty of scratches, etc, and quite faded. it cleans up OK, but I had plans to repaint the car to its original glory. The body itself has very few minor flaws the two most major I have pictured, and they are simply small cracks in the fiberglass panels.The trunk liner is gone, and the trunk has been bent in slightly to clear the headers. The interior is all original and complete. It is pretty clean, the drivers seat is torn, and the passengers seat has a small tear on the side (pictured). Odometer shows 182,595, but the title reads EXEMPT due to the age of the car. In Georgia as of 2013 it is able to register as a ANTIQUE vehicle, and that means no inspections, or emissions testing. The insurance on the car is very cheap, I paid $90 a month, where my 1997 Buick Regal costs me twice that!
I PERSONALLY HAVE OVER 300 HOURS OF TIME IN THE MOTOR BUILD AND ORIGINAL SWAP
The drivetrain swap was done to the car, and driveable. I had the car registered and insured until recently. The stock 3.8L supercharged V6 motor produces 240 Horsepower, and 280 Ft-Lbs of torque. The only things that were not completed when the drivetrain swap was done is some minor wiring such as the speedo, tach, and odometer are not wired to the harness yet, but the car ran perfect, and drove awesome. Gobs of torque felt with the custom solid torque strut. This winter I pulled the car into my shop to drop the cradle and do some performance modifications to the drivetrain.
The mods to the motor are as follow:
Ported TB
Ported LIM
Ported Gen III M90 Eaton Blower with silencer ports block off plate installed
ZZP MPS system installed for easy pulley swaps, with 3.1, 3.25, and 3.4 Pulleys
ARP Head stud kit
ARP Header Bolts
ARP Rocker Bolts
Aluminum LIM gasket upgrade
Comp Cams XP Cam
Comp Cams 105# Valve Springs
Comp Cams Valve Locks
Stainless Steel SI Valves
ZZP Titanium Valve Spring Retainers
Ported and Polished Heads
Stainless Steel PCV covers
Walbro 255LPH Fuel Pump
(6) Siemens Deka 60# EV1 Fuel Injectors
ZZP High Volume Water Pump
ZZP Flex Plate
ZZP 10.5MM Plug Wires (red)
ZZP Modified Fuel Rails (black powder coated)
ZZP Polished Aluminum Valve Covers
ZZP Drilled Thermostat
ZZP oil Volume kit
Speed Daddy Headers with upgraded clamps
3" to dual 2.5" Y pipe
Dual Glasspacks
2.5" tail pipes with dual, Authentic Chevrolet C6 Corvette tips
TransGo shift-kit installed in the 4L60E-HD Transmission
Custom Low mount Alternator Bracket
New Radiator
All New Poly Bushings (front set needs to be installed still)
(4) New KYB GR-2 Struts
New Stainless Brake Lines all around (front set needs to be installed still)
When I was driving the car, before I dropped the cradle to add all the new performance parts it was in great driving condition, started every time, ran perfect with 0KR, shifted excellent transmission was very tight, never overheated, and stopped excellent. When It is put back together it will be an amazing street machine! I had plans to have the car tuned to run on E85(Ethanol), and all the modifications to do that have been done, or run it on pump gas no problem.
To finish this project car the fuel pump and lines must be hooked up, install alternator and starter, ignition system installed, hook up the plumbing (coolant lines, vacuum lines, etc) fill all fluids (Oil, Trans, Coolant), then hook up the wiring harness to the motor and transmission, Make the final torquing to cradle, and motor mount bolts, then it is ready to start and drive! All the parts needed for the car to be put back together are here. PLUS I have several large boxes worth of good spare stock 3800 motor parts, and the original OEM Fiero parts. The motor has not been run since the modifications have been made, so all of the parts are still NEW AND NEVER USED. The 3800 does not have a break in procedure for the cam, so it is ready to run! I would highly recommend a professional tune be done on the PCM for maximum gains from the modifications. The setup on this motor is highly capable of over 300 Horsepower to the WHEELS, and even more TORQUE. I DAILY DRIVE a Buick Regal GS 100+ miles, it also has the same motor as my Fiero, but with less mods done. The mods to it are, High Compression Series III N/A Block, VS cam, Ported Blower with 3.5 pulley, Speed Daddy Headers, full exhaust, and was Dyno Tuned @ 271HP and 331FT-LBS TO THE WHEELS. The Fiero has a more powerful setup in a lighter RWD Platform, and a TON more money invested. I have tons of experience working on, and modifying these 3.8L supercharged motors...
I have $7,418.78 invested in JUST PARTS for the Fiero to date, and am very meticulous about keeping receipts, I do not have every receipt ever, but I do have most of them. I understand that my loss will be someones gain, and am at a point and time in my life where projects and toys are not my priority, so as sad as it makes me it is time for me to move on from this beautiful classic collectors car.
Complete Engine gasket set…..293.79
ZZP aluminum LIM gasket….45
ZZP transmission gasket….20
Speed daddy headers…..268
ZZP header clamps…..25
Comp Cams XP cam…..325
Comp Cams #105 valve springs…..105
Comp Cams valve locks….25
ZZP titanium valvespring retainers…90
SS PCV covers….38.75
Walbro 255LPH….95
TransGo shift kit and filter….76.11
ZZP pulley puller…..125
ARP head studs....100
ARP header bolts....20
ARP rocker bolts....20
ZZP flex plate…50
ZZP flex joint….40
ZZP thermostat…..10
SI stainless valves….80
ZZP water pump….50
ZZP sealants/lubricants…..41.50
ZZP 3.25 MPS….100
ZZP Polished Valve covers….210
ZZP modified fuel rails…..200
60# injectors…..250
ZZP plug wires…..100
Assorted Advance Auto…..224.91
1998 GTP motor+trans(40,000 miles)….1200
Poly bushing kit.....113.95
4 KYB GR-2 struts.....120.54
New radiator.....150.39
1998 GM 3.8L manual set....80.00
HAYNES Fiero Repair Manual.....????
GM Fiero Repair Manual....????
Stainless brake lines.....50.04
Supercharger Pulley Puller....80.00
…………………………………………………………Motor/Transmission total = $4,260.06
………………………………………………………...Cost of drive train swap parts = $1243.80
…………………………………………………………Cost of 1988 Fiero Formula = $1,000.00
…………………………………………………………Cost of Misc. Fiero parts = $614.92
…………………………………………………………Cost of custom header back exhaust = $300
GRAND TOTAL INVESTED = $7,418.78
JUST SO IT IS CLEAR THE CAR IS CURRENTLY A ROLLER AND IS NOT COMPLETELY PUT BACK TOGETHER. THIS MEANS YOU WILL NEED A ROLLBACK WITH A WINCH OR SIMILAR TO LOAD THE CAR ONTO A TRAILER BECAUSE IT CANNOT BE STARTED AND DRIVEN, IF YOU HAD ENOUGH MAN POWER IT MAY BE POSSIBLE TO PUSH THE CAR ONTO A TRAILER, I AM WILLING TO HELP, BUT I AM NOT RESPONSIBLE FOR THE MOVING OF THE CAR/PARTS.
I have some videos I took of me driving the car right before pulling the car into my shop this winter.These ARE with the 3.8L V6 motor in the car.
I can link you to these on Youtube if you message me and ask for them.
The car is currently located at my home shop, in between Powder Springs, and Marietta, GA off of Dallas HWY (120)
I highly suggest, as I would with any vehicle purchase, that you contact me and personally come by to see the car in person. I am not trying to hide anything, and have been completely honestly throughout the listing about the vehicle, but of course it is always better to view in person! I have hundreds of pictures of the car from through out the build, so if you have any questions PLEASE ASK THEM BEFORE BIDDING. I did my best to think of everything to say about the project, but cannot garentee all the small details have been mentioned. I will have no problem answering any questions, or emailing you pictures of anything specifically requested.
I work week days, and attend school, so I am a busy person, but will do my best to keep an eye on my email. Feel free to EMAIL, TXT, or CALL me with any questions as well. If you are seriously interested get in touch with me, I am a nice guy, and am willing to work with you. Thank You,
Chris (989)-312-1376, [email protected]
Wow if you were in NY I would be ALL OVER THIS! O M G !
so pissed but I can not make it to florida no way
that happens with ebay you sell it and they dont come through or they try and talk you down. also had people from over seas or merchent marines trying to buy it at asking price and then steal your car. Its sad when you cant trust what people say. I do wish you the best of luck on selling it....wish you would have finished it first......................
If u want to own a car like that u can't be afraid of what it needs to be finished that's a mostly done project for sure
I cant cause of work I work 7 days a week or im on call
I really wish I could or you were close
^ ask for a day off or I'm sure you have some type of vacation day. If you want it that bad you'll find away to get the day off ;)
Car is still available, sadly if it doesnt sell soon I will have to sell the body as a roller to a gentleman who made an offer that is hard to refuse. Then I will be parting out the motor, etc...
Status
