hey hows it going had the same problem if you have a 160 or 180 u need to get a code # deleted from the pcmi have put a lower temp thermostat in and now after a certain time my service engine light comes on and when i get the code checked it tells me the thermostat is not letting engine temp come up to normal operating temp ,,,what do i need to do
if you choose to not go with a stock then the 180* drilled is the way to go. i can vouch for it as well as webracin can i see. just takes a bit to warm that cargo up haha
Still going back and forth whether to do the "winter switch" on my thermo on the Imp.
Unless its drilled, why would you need to change it?
A 180* will not require the code to be removed. I believe 160* or 170* is the threshold that the engine has to get to so it doesn't set the code.
A 180* doesn't change how long it takes your car to warm up. Heater performance isn't really changed either. Drilled thermostats do make your car take longer.
