    TIPS:
2002 GTP Grand Rapids MI
02wdave
I have for sale a very nice project for someone that is mechanically inclined I started my build last year and was injured on the job and now I can't finish the project because of money and my injury. It is a 2002 GTP four door car it is bronze in color. I have most everything to finish it and everything goes with the car I'm not parting it out at this time. This was going to be a fun toy for summer but it is my loss and your gain. It has a built up 3.8 stock lower end a comp cam XP cam shaft, single stock timing chain, LS6 valve springs, ported stock heads, ARP head bolts, multi layer steel felpro head gasket, comp cam 7.050 hardened pushrods, comp cam roller rockers, ZZP polished valve covers, ported polished lower intake, ZZP 8 rib kit with 5% overdrive balancer, oil pump extension, ZZP stainless headers, 3" down pipe, full 3" magnaflow exhaust, Gen 5 blower with welded silencing holes new bearings and coupler ported inlet and H beam, polished ZZP N* adaptor, N* throttle body and mass air meter, K-N 4" intake 60# deka injectors, polished ZZP fuel logs and regulator, full size series 3 inter cooler with phenolic plate, ZZP front mount heat exchanger with polished ends, hi flow fuel pump and intercooler pump, GXP wheels and brakes front and rear, built tranny with all hardened shafts and poly mount, motor also has all poly mounts, lowering springs, KYB shocks, roof rails, F1 carbon fiber hood, SLP wing, ZZP strut tower braces front and back, limited edition gauge cluster and door panels, 20% tint on every window i know im forgeting things this would be a very fun car once finished. Shoot me offers I need it out of here
Sorry guys I forgot to put the price I'm asking 4500 because it does need the work and the interior is in pieces if you would like picture I have some on my phone please let me know it sad but she needs to go I can't do the work I want with my leg the way it is if you want I can send pictures though text message 616 881 6010
I got them all for 20 dollars I thought I would try them I have a set of stock one that are brand new as well
Sorry guys I just can't do all the running around to part it out make me an offer I need it gone I understand that I won't get my money back but I have a lot of good parts for it help me out
Hey i emailed you because i saw it on craigslist also. How is the underbody of the car where the common rust is like rockers, rear strut towers, gas cap, and wheel wells? Also what has to be finished on it or done to it so it is driveable? Thanks -Zach
