Line Output Converter.
So I can still tap into the system in the trunk as long as I use the INPUT to the amp? I kinda figured I'd have to use the input instead of the output. I don't suppose anyone has a wiring schematic of the Bose amp?I have a whole pile of aftermarket crap wired up to my stock Bose HU. 3 amps, sub, 6x9's plus a harwired MP3 line input. A line convertor wont work well unless you run it off the front speakers, the rears are low and high pass filtered in the bose amp so there isnt anywhere to get a full audio signal for a line convertor. The easiest way is to tap into the low level inputs from the HU to the bose amp, solder RCA leads to them. I get weird issues where when I first turn the car on my HU wont turn on unless I hit the window down button and stuff though....
Yea pretty much, I dont remember the wire colors though. Also just to be clear, you dont hook the amp input wires to a line convertor. You just tap into them with RCA's and plug them into your aftermarket amp.
i've never had a bose in any of my cars but would it be wacky to just get a different head unit and run your own amp? or get a different head unit and run both amps. i don't know how the bose amp is connected to the head unit or if its straight to the battery for power. seems like you could run rca's out of a head unit to either amp. the bose on the 6x9s or the little sub it powers if it has one and the sub rca out to your aftermarket amp.
Please re-read the title of this thread, and then re-try to reply properly.
i just had to replace my fuse for my amp power wire, long story short previous owned blew it while removing his system.
finally get my shizz semi set up (need a humount) and unfortunately it sounds like crap!
i have little to no bass untill i crank the volume so high that the non bass part is too freaking loud...
or maybe its supposed to be that way? its the same head unit and amp/sub i had in my tbird. i feel like something is amping up the speakers.
when i spliced in my head units harness, the guy told me to put the amps remote wire and another blue wire to the remote wire on the harness.
could the mysterious 3rd wire possibly be the bose amps remote wire?? i want to keep the bose speakers without having to rewire them to the head unit, thats not an option i refuse to do that a 4th time hah. if there was some way for me to just cut out the bose amp/sub from the factory and then keep the rest the way it is thatd be great...
