Bull**** on the $200 for injectors and a fuel pump. I'm calling you out on that. There's no way in hell you will find that new at that cost. Post the links to these. Your trans comment again bull****. Why because its not going in a Fiero its going in a piggy and I don't give a **** how it drives it the trans is going to go out. People have GTP's with stock trans go out all the time and they don't make near enough power a turbo will. How in the hell do you think that he won't eventually need a built one or a replacement is bull****.cheap injectors and a cheap walbro fuel setup will do 375whp pretty easily.... $200 there.
wastegate/bov/intercooler/install kit will run you about $300 on ebay prices.
A wideband is a good idea, not needed.
I ran a bone stock trans in a lighter car running really low 11s, so you really dont need a trans if you are not a stupid asshole that doesnt know how to drive a car making power.
Tuning is cheap, and you dont really need to even tune anything if you keep the whp under 375 (17psi) and run on a stock LT1 maf.
ghetto turbo kits have been done often, on stock transmissions... they work fine and are really easy to do.
A seasoned owner with a lot of spare parts and the right resources could do this for potentially under $1,000 but you have to be more realistic.
im new to the GP world from the truck world. i know many people with modded LS swapped trucks and stock 4L60E trans that handle 350-400 wheel HP. i would assume a 4T65E or 4T65E HD would be able to handle quite a bit. then again this is Longitudinal trans vs Transverse trans, so there may be some other weak links..
